Stationary Engines Discussion Forum
fairbanks morse mag timing
darryl w
08-14-2007 10:09:16
i got a new mag for my fairbanks morse dishpan z
and i"m not sure how to get it timed to the engine
Dale(MO)
08-17-2007 17:21:47
 Re: fairbanks morse mag timing in reply to darryl w, 08-14-2007 10:09:16
Darryl, If it is the same as the Z, style D, 1 1/2 h.p., I "think" (it's been at least 20 years since I did this) there should be a mark on the flywheel. You line this up with the pipe plug on the backside of where the mag goes in, making sure the timing mark on the mag gear is clearly visible through the plug hole. I sure hope this helps.
Dale(MO)
darryl w
08-20-2007 06:01:51
 Re: fairbanks morse mag timing in reply to Dale(MO), 08-17-2007 17:21:47
thanks i will give it a try.
