Stationary Engines Discussion Forum
Model E
broe
08-17-2007 19:53:31
I have a model E103R and am wondering where teh serial number is located?
Danno
08-22-2007 05:17:09
 Re: Model E in reply to broe, 08-17-2007 19:53:31
just to confirm what has already been said (and say it differently). Look on the exact opposite location of where you found the E103R and you will probably see something that looks like this:
third party image
ken in texas
08-18-2007 15:47:11
if you are speaking of the model E stationary engine, the numbers are on a cast plate below the magneto. The plate is a side engine cover,
the Unforgiven
08-18-2007 21:19:47
 Re: Model E in reply to ken in texas, 08-18-2007 15:47:11
Yeah, if it is a model E JD, the number is on a tag on the governor cover, if it is an early "brass tag" JD, the tag will be on the rear of the base, right under the fuel filler hole.
the Unforgiven
08-18-2007 10:48:14
What kind of engine is it? E103R sounds like a John Deere part number.
broe
08-21-2007 19:28:56
 Re: Model E in reply to the Unforgiven, 08-18-2007 10:48:14
Sorry it was a JD. I found the nuber 360761.
Thanks!
dobber
08-25-2007 19:22:54
 Re: Model E in reply to broe, 08-21-2007 19:28:56
Yours is a 1944 year model falling in the range of 356601-360790. E engines were made 1923-46.
