Buying: vintage c-4 sparks needed ASAP
Mike.S
09-07-2007 16:50:13
Im in need of some old c-4 champion sparks to run my stationary hit & miss engine..
i have a picture of it..
willing to drive the distance to pick up.
http://i185.photobucket.com/albums/x293/MikeCreatedDisco/spark.jpg
Jim Hilton
11-06-2007 15:56:19
 Re: Buying: vintage c-4 sparks needed ASAP in reply to Mike.S, 09-07-2007 16:50:13
I have a model a ford. You can buy your c-4's from Synder's Antique Auto. A/T Model A And model T distributer. a c-4 is a model a ford plug. They also have auto lights.
Graeme Wardlaw
10-10-2007 22:25:05
Hi fellow engine man. I am a long way from you but shared the same problem. I went to my local, national after market parts dealer and asked for a look at the latest ref manual. Although they dont make all the heat ranges (they pick around the middle) I was surprized to find they were still available from the manufactuer (champion) If you just ask behind the counter you will get a no sir. Give it a go, I have over 100 engines before 1930 and have a stock of new plugs for them all. Any problems feel free to email me and I may be able to help from here. Good luck and cheers Graeme Wardlaw.
dobber
09-12-2007 10:55:50
C4 isn't the correct plug. OEM from old Champion chart is 1 COM (#1 commercial) which was replaced by Champion W-14 (stock # 569) which should be easy to find. Hey I even have a bunch of new ones on shelf. W-14 also subs to AC C75 or Autolite 3075.
Mike.S
09-11-2007 16:22:03
 Re: Buying: vintage c-4 sparks needed ASAP in reply to Kent of SW MO, 09-07-2007 16:50:13
thanks, i got it working but im going to look for one
the threads on this sparks odd they say..
dobber
09-12-2007 09:12:35
 Re: Buying: vintage c-4 sparks needed ASAP in reply to Mike.S, 09-11-2007 16:22:03
Threads aren't odd they are just larger 7/8 inch 18 thread per inch. The W-14Y is a plug with projected core. Are you sure C4 is the correct OEM plug for it? Vendors like Starbolts and Hit & Miss will have the plug you need.
dobber
09-11-2007 13:41:51
C-4 later became Champion W-16Y a plug that hardly anyone stocks today. Check with engine parts and spark plug advertisers at enginads.com or smokstak.com
