Stationary Engines Discussion Forum
Lincoln SA200
Whisper
10-08-2007 09:58:16
I'm looking for information to convert the 115 volt DC power recepticle to 115 AC power. Lincoln has no information. Does anyone know if this can be done and how?
Kentb of SWMO
10-10-2007 05:59:13
 Re: Lincoln SA200 in reply to Whisper, 10-08-2007 09:58:16
The recepticle is there so you could run UNIVERSAL electric motor equipped tools like electric drills and grinders. DO NOT plug a AC ONLY tool into this receptical as you will butn up the tool and your welder.
Kent
doogdoog
10-08-2007 22:10:55
Aloha, If you could find a converter to convert the 115v dc to 12v or 24v dc, then you could hook that up to an inverter for ac. The problem here is the 115v dc output of the welder. Is there any way to bring out 12v or 24v dc by rewiring??
Mahalo,
doogdoog
JohnMB
10-09-2007 20:19:38
 Re: Lincoln SA200 in reply to doogdoog, 10-08-2007 22:10:55
The exciter armature is only rated for about 8.5 amps and at 12 volts this would only give 100 watts. Not really enough to do much.
JohnMB
10-08-2007 21:13:10
There were many models of SA-200. I believe that all of them were all DC. The main fields were supplied by an exciter on the end of the main shaft. The DC receptacle was also supplied by the output of the exciter. Since there is no AC in the machine it cannot be converted.
