Stationary Engines Discussion Forum
Newbie Sattley questions...
52b3pw
10-27-2007 18:22:21
I removed the rotating assembly tonight and saw that the babbit bearings had the number T-80 stamped under them. When I removed them, I noticed that the rod caps were shimmed with some sort of thick gasket, about 1/8th of an inch. The rod caps are stamped with the numbers T-20. Is it possible that during its working life, someone replaced the bearings with the wrong size, or is the gasket/spacer correct?
Also, when I tighten the rod cap more than hand tight, the rotating assembly binds up, slowing down significantly. I do not have the connecting rod or anything connected to the crankshaft; I am spinning the crank by hand. This is what makes me think the wrong bearings are in it.
I have not located a book/manual about this engine yet.
Any help would be appreciated.
Steve in NJ
52b3pw
10-27-2007 19:30:34
 Re: Newbie Sattley questions... in reply to 52b3pw, 10-27-2007 18:22:21
The engine is a Sattley 2hp, 500 rpm with solid flywheels.
The half shell, or what I thought were babbit, do not have the tab to stop the spinning.
It seems to me that the spacers were used because the bearings were too thick and the caps would not go on flush with the base.
Just a thought.
I also located a manual on 1 1/2 hp Sattley engine that I will order on Monday morning.
Steve
Senlim
10-27-2007 19:22:15
I don't know the make of engine you refer to but a few general comments on old engines follows.
If the bearings are half shells check if they have tabs on them to stop them spinning. On older engines spacers were used to stop the half shells spinning. Very useful as older engines often kick back and the more modern anti-rotation tabs would not stop the shells spinning on the revers kick back.
Again on older engines with hand scraped bearings spacers and or shims were used to allow for the correct running clearance of the bearing and adjustment with age and use. You may need to make up some shims to get the required running clearance and check the bearing fit with marking blue and the clearance with plastigauge.
Good luck
Senlim
