Stationary Engines Discussion Forum
wisconsin vp4
Dave Fuller
12-02-2007 09:38:27
This message is a reply to an archived post by JOB on September 09, 2005 at 18:38:27.
The original subject was "Re: wisconsin vf4".
My question is about the numbers on the mag holes, my cap has the numbers in the wrong order for firing in counterclock rotation looking at the cap. After I found #1 I put the wires to the plugs in 1,3,4,2 order, that differs from the actual numbers on the cap, The engine is in perfect mechanical time but is hard to start and back fires through the carb on propane. I can pull off #4 wire and the backfiring stops. Help
dobber
12-05-2007 22:15:21
 Re: wisconsin vp4 in reply to Dave Fuller, 12-02-2007 09:38:27
http://www.wisconsinmotorscanada.ca/indexsec4.html
or
Tramway Guy
12-05-2007 09:19:27
Backfiring might be a sticky intake valve!
teddy52food
12-02-2007 19:15:26
Try a new or different plug in #4.
Kentb of SWMO
12-02-2007 16:51:19
The numbers on the mag cap a meaningless. Insert the plug wire by fireing order. The backfireing problem you explained I have no answer for.
Kent
