Stationary Engines Discussion Forum
International M running direction.
SeMo
12-06-2007 20:24:30
I just started working on an engine I know little about. Which way does an International M run? Flywheel turning toward front or back of engine? I have the engine crank and it will fit on the mag or opposite side of the crank.
George Andreasen
12-07-2007 03:49:23
 Re: International M running direction. in reply to SeMo, 12-06-2007 20:24:30
First of all, congratulations on having one of the best engines designed...I've got two of 'em! The flywheels spin toward the REAR of the engine. There should be a grease cup on the end of the crankshaft for lubing the connecting rod. Make sure you give it a couple of twirls before starting. Instruction manuals are available from several online suppliers along with replacement parts, etc.
