Stationary Engines Discussion Forum
Hercules IXA5-Timimg
james Kennedy
12-08-2007 06:43:52
There was a previous post that provided some good information on how to set the timming of a IXA5 engine. This is a followup for a bit more clarification.
When you mention flywheel, are your referring to the wheel in which the starter messes with, on the back of the engine?
Also, should the DC mark be possitioned in the center of the cavity where the starter installs?
And, should the mag click immediatly after the DC mark or should there be a bit of gap between when the dc mark appears and the mag clicks. (I am asking as the engine runs a bit rich and I think the timing may be off-I cleaned the carb).
Any information would be appreciated.
