Stationary Engines Discussion Forum
Hercules IX Series-Water Pump Repair
james kennedy
12-10-2007 14:29:10
Could anyone provide a bit of detail regarding the water pump on this unit?
Mine is leaking. I do not have a parts manual. I would like to remove the pump and repair it; i was looking for some up front guidance before I start. It appears as if the pump is mounted to the mag on one end and maybe the oil pump on the other.
Does the pump take a replacement seal, or is it just a mater of repacking it?
Is there any part that would need to be handled carefully to avoid damage?
Any information would be appreciated.
Kevin Meier
12-10-2007 17:26:36
 Re: Hercules IX Series-Water Pump Repair in reply to james kennedy, 12-10-2007 14:29:10
Can you send a picture of the pump and the impeller when you get it off. I may be able to help you in rebuilding the pump if i can see what you are dealing with.
Kevin
james kennedy
12-10-2007 18:19:17
 Re: Hercules IX Series-Water Pump Repair in reply to Kevin Meier, 12-10-2007 17:26:36
I will take a photograph of the pump still installed.
Thanks for the interest.
james kennedy
12-11-2007 06:36:24
 Re: Hercules IX Series-Water Pump Repair in reply to james kennedy, 12-10-2007 18:19:17
Photograph forwarded as requested.
