Stationary Engines Discussion Forum
IHC 3HP M
JD2510
01-20-2008 16:22:22
I NEED TO KNOW WHAT TYPE OF MAG I NEED TO USE FROM WHAT I HAVE SEEN I NEED A GEAR DRIVEN MAG BUT MY HEAD HAS SPARK PLUG AND IGNITOR HOLES, I HAVE NO IGNITION PARTS WITCH WAY SHOULD I GO TO GET A SPARK
JT
02-17-2008 15:48:57
 Re: IHC 3HP M in reply to JD2510, 01-20-2008 16:22:22
They used a IH model "R", I think was the model "magneto" that was actually a little generator that fired the ignitor, then the later ones uses a Wico EK mag. There may have been others, but that is the 2 I have seen.
Jim
Harold H
01-29-2008 10:48:42
In the mid 1930's the engine was built in two sizes. The 3 1/8" bore x 3 1/4" stroke was 1 1/2 hp @ 600 rpm to 2 1/2 hp @ 1000 rpm. The larger engine was 4" bore x 4 1/2" stroke 3 hp @ 600 rpm to 5 hp @ 1000 rpm. Both were standard with a high-tension, rotary type Wico magneto with impluse coupling. This information is from 1935 general catalog.
Harold H
pickawayCOmike
01-27-2008 17:54:59
So you have a spark plug hole and an ignitor hole ?? ... sounds like someone has put a different head on your engine , is the head off ? check bore 3.250 will be a ignitor engine that uses a IHC model L magneto . But if your bore is the larger i think 3.500 it will be a spark plug engine that used a impulse mag by BENDIX ( i think thats what they used ) I would say that you have a ignitor engine Now there are 2 varitions of ignitor engines . The early ones was called an understrike type where the ignitor was pushed from the bottom of the dog that is on very early M's then the later types was what I would call a normal set up .I have the understrike type and parts are well ... NONE. But figure out what you have first and go from there
pickawayCOmike
01-27-2008 18:24:40
 Re: IHC 3HP M in reply to pickawayCOmike, 01-27-2008 17:54:59
SHOOT ..... .... nevermind , i just was looking and saw you have a 3 hp ... i was talking 1 1/2 ....sorry my bad
Eddie M
01-20-2008 18:04:58
Do you have a serial number?
