Stationary Engines Discussion Forum
Briggs wmb gas tank ?
Neal in Alabama
01-30-2008 19:01:42
I have a 1957 wmb that's missing the gas tank. My question is, can I use a tank that is mounted up by the motor rather than below that requires a check valve? I have a small tank with a sediment bowl that I would like to use.
Thanks, Neal
Tinker In TN
01-30-2008 20:01:28
 Re: Briggs wmb gas tank ? in reply to Neal in Alabama, 01-30-2008 19:01:42
A gravity feed tank is used on engines which use a carburetor with a float and needle valve. The WMB doesn't have a carb with a float. Use the gravity feed tank on the WMB, and the gas will run out of the carb, until the tank is dry.
If you adapt a carb from a model N, then you can use a gravity feed tank.
