Stationary Engines Discussion Forum
Wisconsin VH4D
JD Gimpl
04-16-2008 22:09:01
OK, I have spark now and need to get plugs. What would you all suggest for this engine.
Also do you know the oil capacity and weight I should use. I want to change oil and then will be looking into the fuel side of things to get this going. Hopefully in time to bale this year.
Thanks JD Gimpl
FixaLinc
04-17-2008 14:32:49
 Re: Wisconsin VH4D in reply to JD Gimpl, 04-16-2008 22:09:01
Newer Champions seem to foul worse. We been using Denso L14-U for quite a while now in all Wisconsins and Continental engines with mags. Good non resistor plug. In AC Delco the AC87 or hotter AC88 work well too. Autolite 3116 works well too. I&T large air cooled engine service manual gives 4 quarts for VH4 & VH4D and says use high quality detergent oil meeting or exceeding SD or SE classifications in 30, 20 or 5W20 depending on your operating temperatures.
Kentb of SWMO
04-17-2008 05:55:56
Most Wisconsins use Champion D-16 or UD-16. Use a good 30 wieght oil. I do not know the oil cap. fill with oil to the full mark on the dipstick, run engine and then recheck the oil level and top off if needed.
Kent
