Stationary Engines Discussion Forum
Antique Briggs Stratton Motor Info Question
JohnNJ
05-10-2008 14:29:58
Question: I just aquired an old Briggs & Stratton Model 14B, Type 202329, Serial # 233987 motor and was wondering if anyone can determin the year this motor was built.
Thanks in advance,
John
p.s. A Google on the motor got me to this site. The thread that matched my google search was a question on the same motor, type and with a serial number only ONE number off from mine( serial# 233987 vs 233986). Unfortuantely, the post was two years old and was a different question.
Kentb of SWMO
05-12-2008 05:25:30
 Re: Antique Briggs Stratton Motor Info Question in reply to JohnNJ, 05-10-2008 14:29:58
Is the generator making power?
Kent
JohnNJ
05-12-2008 19:28:49
 Re: Antique Briggs Stratton Motor Info Question in reply to Kentb of SWMO, 05-12-2008 05:25:30
Kentb,
Yes - the generator is making power. It is a Winco model F3000. After gassing up the motor (which was ran dry before stored for decades ago) it ran flawlessly as if the unit was new. I was very surprised!
I did not load test the generator by using an amp-probe under load, but I had two circular saws, a radio and light running together and the motor did not bog down the motor. I had to be running very close to 20 amps which the generator is rated at.
The only things I did to the generator after knowing it would run is an oil change (now running full synthetic) and a good cleaning. I think the oil and grease preserved the unit from rusting.
I have a larger generator of about the same time period. I think it was home made, but looks heavy duty commercial. The motor is a Briggs & Stratton model 23FB, type 203511, serial number 250838. The generator is a HUGE Western Electric unit rated at 70 amps at 120 vac/35 amps at 220 vac and is also tapped for single phase as well as 3 phase 220 vac. This generator is rated at 100% duty at a low r.p.m. (just above idle) The reason why I think it is home made is the motor is not large enough to run the generator at full capacity. I found this unit in the lcal dump in poor condition shortly after Y2K. I resotred it to better than new and I use it when ever we have power failures.
John
Kentb of SWMO
05-13-2008 05:30:19
 Re: Antique Briggs Stratton Motor Info Question in reply to JohnNJ, 05-12-2008 19:28:49
Yes, the 23FB is not big enough for the generator. The 23 FB at 9 HP is only one half the HP need to run the generator at full output. On the plus side I would rather have a generator UNDER engined. This way you willnot burn out the generatore from overloading.
Kent
Bob
05-10-2008 16:07:08
September, 1954????? ???
JohnNJ
05-10-2008 16:45:23
 Re: Antique Briggs Stratton Motor Info Question in reply to Bob, 05-10-2008 16:07:08
MANY THANKS!!!
John
p.s. - The motor is on a generator frame made by Winco. The motor was found in an old shed an may not have started for decades. There was no gas or crud in the tank and the gas line shut off valve was in a closed position. I first fired it up with starting fluid and it started and ran as I shot small amounts of starting fluid into the carb as if it was fuel injected. During the first 2 seconds of the initial start all kinds of crap came out the open exhaust pipe. Afterwards, I poured fresh gas into the tank, opened the valve, wound up the rope and pulled it. It ran like a champ! After a good gunking and fresh oil change, it looks and runs flawlessly. Thanks again for the information.
