Disolve this gunk...
Charisse Dixon
10-15-1999 23:03:05
Please help me to clean out the water tank on my engine without having to pull the sleeve. It is an I/H "M". 1 1/2 H. with a rubber ring around the sleeve, so I don't want to pull it. It has some used oil poured in, and rotted maple tree crap...thick black gunk. Lots of lime, too. Any suggestions are greatly appreciated! I want to get this back together & hear it run!
Charisse
10-18-1999 14:07:06
 Re: Disolve this gunk... in reply to Charisse Dixon, 10-15-1999 23:03:05
O.K. guys, you gave me the poop on how I can get out the scale, thanks! But what do you suggest I use to get the gummed used oil out without harming the rubber seals? Is there any solvent in particular I DON'T want in there?
Easy-Off ???
10-18-1999 21:42:21
 Re: Re: Disolve this gunk... in reply to Charisse, 10-18-1999 14:07:06
My hubby just suggested I try oven cleaner to disolve the oil...does this sound alright? ANY feedback on this is appreciated - Charisse
Louis G
10-18-1999 22:37:13
 Re: Re: Re: Disolve this gunk... in reply to Easy-Off ???, 10-18-1999 21:42:21
Justice Brothers Engine Degreaser works good and will not hurt the rubber seals.
Thanks
10-19-1999 10:58:13
 Re: Re: Re: Re: Disolve this gunk... in reply to Louis G, 10-18-1999 22:37:13
Thanks Louis, where do you get the stuff? - Charisse
Louis G
10-19-1999 22:57:12
 Re: Re: Re: Re: Re: Disolve this gunk... in reply to Thanks, 10-19-1999 10:58:13
Where are you located? I can get you the name of the distributor in your area, or you can go directly to the company at justicebrothers.com for the name of the closest distributor. Justice Brothers is not distributed through the national chains; therefore, I cannot tell you that it is availiable at store X. I am a distributor in Texas and could ship it if you cannot find it locally.
Neal
10-17-1999 21:37:57
Try Descale-it products they have a product that will remove the scale. The address is info@descale-it.com good luck Neal
Mike C.
10-17-1999 20:04:49
A friend also restores engines like that and worse. He suggested muratic acid, small amount of phosphoric acid in the hopper, let it set awhile, then dump out and check. If you are scared of trying something that strong, try vineger straight and let it set for a while. It works in coffee pots
