How did it run?
Steve
10-23-1999 20:35:25
I saw a small briggs at portland last year running I believe on propane??? The fuel line was wrapped around the Muffler.What was the fuel used? I dont remember seeing a carb.The fuel was drawn thru a jar of colored water. How did it run?
Motec Engineering
10-29-1999 07:55:55
 Re: How did it run? in reply to Steve , 10-23-1999 20:35:25
I did not see this motor, but it sounds simple to me.
The fuel line around the exhaust was to turn the liquid LP into a gas. (You heat water to turn it into steam.) I'm sure that there was a presure regulator to lower the LP presure. Once you have the LP in gas form, it is just a matter of mixing the two gasses (air and LP). The jar with the water was used to do this.
Propane-the other white gas.
Matt
Motec Engineering
