Looking for Continental F162 info and parts
Bud
10-27-1999 18:52:23
I have a mid 1954 Continental F162 engine in my Lincoln SA-200 welder that needs to be rebuilt. My questions are, is a rebuild kit is available? Also where could I find a rebuilt block instead? And finally will the F-163 block fit ? eg. are the bellhousings the same etc?
Thanks in advance!
Bud
darin fisher
03-26-2006 14:20:04
 Re: Looking for Continental F162 info and parts in reply to Bud, 10-27-1999 18:52:23
i just purchased an overhaul kit for my f 162..new pistons,rings,bearings,valves,guides,gaskets,,,675 dollars. email me and i will give you the info.
mudd
09-08-2006 13:43:40
 Re: Looking for Continental F162 info and parts in reply to darin fisher, 03-26-2006 14:20:04
help if possible !!! i need timing specs on f226 continential engine w/ timing gears... which way does the dot on gears line up cam gear has 2 dots crank gear has 1 do they line up together or top/bottom also which way does engine turn and do you know the firing order for this flathead f226 !!!! any help is much appreciated
kris erickson
03-30-2000 11:25:51
have you contacted lincoln electric?. they have complete parts and wiring diagrams for all their welders,also a great tech support line. have yourmachines serial # and code # they have been a big help to me in rebuilding my sa-200 .if i can help e-mail me welder7789@altavista.com.
Ken Liden
08-17-2000 21:18:59
 Re: Re: Looking for Continental F162 info and parts in reply to kris erickson, 03-30-2000 11:25:51
Continental Teledyne is still in business. Most engine parts are still available from regular auto parts stores. Also Dave VanNess Engineering is an ex Continental employee who is in the business of making new old Continental castings.
Rick
01-12-2000 15:50:26
HELP!!!!! !!!!! !!!!! I need a repair manuel on the 1947 Lincoln welder or someplace where i can download the repair information.
Russ
11-25-1999 06:50:23
Try these:
Harley Equipment 1-800-356-8108
The Engine Center 1-800-726-8870
Montes Equipment 1-800-228-2625
Continental 1-800-932-2858
I'm working on an F226. Let me know how yours turns out.
DVN
11-04-1999 21:21:01
give van ness engineering a call 201 445 8685. I am sure they can help with all your questions. Dave
