Ignition Points
Joe R
10-30-1999 19:34:56
I recently acquired 3 Delco Light Plants. 1 of them doesn't run very well because the points are badly worn. If I swap the breaker set from another motor it runs fine. I'm sure points will be hard to find. Is there a way to recondition them? I was thinking of usine the ends off a new set of points and soldering them in place of the worn ones. If that doesn't work, I'm out of ideas. Hope someone can help.
Joe R
kevin
10-31-1999 11:36:08
 Re: Ignition Points in reply to Joe R, 10-30-1999 19:34:56
Get the number off of the distributor and take it to an honest to goodness parts store (such as NAPA) and they should be able to get you a set. The retail parts houses a lot of time don't like to do this. I has a job in college years ago selling auto parts, and Delco used the same points for a gazillion distributors such as AC tractors, Chevy 6 cyls, etc.
Joe R
10-31-1999 20:51:21
 Re: Re: Ignition Points in reply to kevin, 10-31-1999 11:36:08
I'm not sure that would work. The distributer is cast into the generator itself. I can remove the points but there is no number identifying them. I was lucky enough to get a couple of emails with some good leads on finding parts. Thanks for your assistance,
Joe R
