Mogul Engine
Ernie Taft
11-18-1999 16:49:37
I have a 8 HP IHC Mogul engine. It is seized up from water leaking from the roof of the storage building into the carb. It had filled the cylinder, and crank case with water. The point system is inside the head and it also is seized. I have the points soaking in a bucket of light diesel for 2 years ,still seized, cylinder still stuck also . Any suggestions ?
Ernie
12-05-1999 13:31:45
 Re: Mogul Engine in reply to Ernie Taft , 11-18-1999 16:49:37
I have the engine loosen'd up and now find I need an intake valve , any suggestions ? The valve is a 2 5/16"face dia. and 8 1/4" valve length. Stem dia. is 7/16". It was suggested I ream the guide out to 1/2" as the guide is badly pitted and loose . The end of the valve stem is threaded to hold the valve barrel on . Is it possible to detemper the stem to turn it to size and thread it ? HELP :>)
