Problem with portable generator
A. TOMSIC
12-09-1999 19:31:49
Anyone out there who could help me, i have problem with my portable generator, make Makita G2400R, type brushless, self exciting, 2 pole. It does not generate. I have checked the coils for the ground and open circuit, ok. The coils had resistance. Can you please e-mail me some information ie. electrical diagram, troubleshooting list and a checklist for start-up if it is possible.
Thank-you in advance for your assistance.
Harold Stotts
04-07-2002 10:54:04
 Re: Problem with portable generator in reply to A. TOMSIC, 12-09-1999 19:31:49
Problem sounds like it was overloaded after circuit breaker failed to open , Replace both diodes and be sure to mark Cathode end and replace one at a time and also take the rotor out and check for open between both commutators. should read about 11 to 24 ohms end to end.
ANother way to test poles is to check for open 2 leads on same pole should read about 24 to 36 ohms.
If diodes check ok, may have to either rewind a pole or both poles or rotor at an electric motor repair shop
