KA-POO, KA-POO, POW!
CD
12-23-1999 20:03:10
It ran for about ten minutes or so yesterday. Not enough to seat the rings, but enough to know that the fuel pump doesn't work good and that the oiler runs WAY too fast. Today we tried it again. Something was wrong, out of balance. Took off. Went ape. Way too fast, shaken and walkin across the floor. Couldn't get to the plug wire, so covered the carb to kill it. Leventy-seven million RPMs a minute, then it happened.
KA-POW! Govenor blew all over heck, iron bits flyin by our heads...lots of play in the main bearings now...nobody told me this would be dangerous.
Jim Smith Ft wayne
01-06-2000 09:02:15
 Re: KA-POO, KA-POO, POW! in reply to CD, 12-23-1999 20:03:10
THE THROTTLE PLATE IS IN BACKWARDS(ASSEMBLED WRONG?). IF YOU THINK IT FLIPPED OVER ON ITS OWN THEN EITHER THE STOP PIN IS MISSING, TAB BROKE OFF ARM ON END OF BUTTERFLY SHAFT OR THROAT WORE REAL BAD(NEVER SEEN ONE WORN THAT BAD).
CD
01-11-2000 08:29:15
 Re: Re: KA-POO, KA-POO, POW! in reply to Jim Smith Ft wayne, 01-06-2000 09:02:15
Nope, nope, yep and yep. Thanks for your imput Jim. All hell broke lose when it ran away, did alot of damage to the linkages when the gov blew apart, have to go over everything VERY carefully. The throat is VERY worn.
jack
12-24-1999 07:20:26
CD what make engine was that an int. m?
CD
12-24-1999 23:29:27
 Re: Re: KA-POO, KA-POO, POW! in reply to jack, 12-24-1999 07:20:26
1919 McCormick/IH 1 1/2 "M", now you got to tell me how you knew that! Ran a wire to the throttle plate and ran her agin today after tightening the bearings(had plenty of shim). Might have to wait till May to get a govenor at Flywheeler's swap meet, gonna buy another fuel pump too. I thought she was about ready for paint, HA! Or, don't count your decals before they hatch....
jack
12-26-1999 04:50:50
 Re: Re: Re: KA-POO, KA-POO, POW! in reply to CD, 12-24-1999 23:29:27
CD I have an int 1 1/2 hp M that ranaway on me with the starting crank on it very very scary the 1919 is the one with the wing nut on the hand hole isnt it?
CD
12-26-1999 22:02:12
 Re: Re: Re: Re: KA-POO, KA-POO, POW! in reply to jack , 12-26-1999 04:50:50
Have gotten up close and personal with that hand crank myself....couldn't keep up when she fired. The handhole is just 4 bolts on the plate.
Ernie
12-26-1999 16:10:03
Why not post the story . It could be a help to others and perhaps prevent injury . What do you think ?
Nathan(GA)
12-23-1999 20:41:12
Yeah, Dangerous, Hard Work, and Fun all at the same time. Hope nobody got hurt. I bet that was exciting. I got a Fairbanks governor control from a fellow. He took the governor out and jammed the butterfly so it runs slow. Well, the butterfly came loose one day while running. It was bouncing around on its cart, trying to take off, lucky it didn't fly apart like yours. I think it is unbalanced too. If you open the throttle very much, she goes to dancing and it aint no slow dance. My fire is a little weak(hard to crank) so I haven't touched it lately. Good Luck
Nathan
Ernie
12-23-1999 20:26:14
Rather a frightening experience and a costly one to boot I'm sure . sorry to hear of your misfortune. Was the govenor working the first go around ? I had seen a net site showing damage when the flywheels blow , was very impressed and for sure will double check my govenor before starting my Mogul .
CD
12-23-1999 20:47:04
 Re: Re: KA-POO, KA-POO, POW! in reply to Ernie , 12-23-1999 20:26:14
It seemed to be working, though not adjusted down. It seems the linkage to the carb turned ALL the way over (slop in the linkage, enlarged butterfly hole, whatever it's called) and then it was WFO and the wobble got worse, the gov tried to slow down, but with it flipped over it worked IN REVERSE! Had a LITTLE play in the bearings before that, but nothing to indicate that it would try to walk away! The gov was replaced because it was broke, maybe the same thing happened to the guy who sold it to us. Thank God it WASN'T the flywheel, bad enogh as it is. Now have to go over everything when thought the pump and mag were only problems...Will be careful, though!
Nathan(GA)
12-23-1999 20:45:24
Ernie, What was that net site with the flywheels blowing? I'd like to see that. Thanks
Nathan
Ernie
12-25-1999 16:00:31
 Re: Re: Re: KA-POO, KA-POO, POW! in reply to Nathan(GA), 12-23-1999 20:45:24
Sorry Nathan , I never book marked the site , It showed dammage from several different incidents. One blew a brick wall out , another destroyed the insides of a shop , looked like a bomb had gone off. If I find it again I will post it here on the bullitian board as a safety hint :>)
