Onan engine
Tom
01-02-2000 17:30:43
I have an Onan engine Model #CCKA-S/35221
SER#. 1790-454362. This engine is on a DC/225amp
welder. I need to overhaul the engine. Are parts availiable? Where do I get them. This engine runs fine but smokes some what and uses oil. Can I get a manuel for this set-up? Please advise, Thanks
Tom
Garry
09-28-2003 04:43:00
 Re: onan engine in reply to Tom, 01-02-2000 17:30:43
I have a CCKM-MS 1899G 24hp Onan for sale. 200hrs on complete overhaul(new pistons, rings and valves) Its a good runner and it comes with or without working air compressor. Gar
rick
01-26-2002 17:53:31
I am replaceing a head gasket on an e140v elite onan engine. I am trying to get the torque sequence and propper toque for the head. Is there any place on the internet I could download this imfo.?
kris erickson
07-22-2001 22:25:03
hi, i have the same welder a lincwelddc2253as. you can get online parts info for any lincoln welder made at lincolns web site:www.lincolnelectric.com you need to have the serial # and code# off of the data plate on the machine. go to the top right of the page click on services that will take you to the parts navigator you will click on that find your code# and the info will pop up. also their is a page for owners manuals online the manual for your machine is not online but get the # for the manual and call lincoln electric and the will mail you hard copies of the owners and parts manuals. lincoln also has a great tech support service phone line.that phone # is on the web site.precise engine service in oregon has all the onan manuals and stock most of the parts,web address:www.perr.com good luck if you need help feel free to e-mail me at welder7789@aol.com i have worked some on old lincoln welders and make my living with lincolns maybe i can help k.erickson
RED Kruise
04-09-2001 17:08:25
I need to find a short block or the parts to overhaul my 16 hp B43M-GA B16/3622A it blew oil out the crank case vent all over everything. one cylinder has a 1/8 in ridge at the top. if a short block is not available reasonable I will need new pistons and rings.
al kramer
03-30-2003 08:54:59
 Re: Re: onan engine in reply to RED Kruise, 04-09-2001 17:08:25
Red, I have similar problem, am looking for place where I can find piston, rings, rods, and hdgskts. I had a rod break on my B43M and would like to avoid local implement dealer if possible.
Maren Donig
02-02-2001 13:43:40
My father has an Onan Engine Serial #1272 537785, Model #CKA-MS 2426G. he would like to get his hands on a Shop Manuel and a Parts Manuel. Also any information on where he can get mor hlp information locally. He lives in Pollock Pines, California which is near Placerville/Sacramento. Please help asasp. Write to me at my e-mail address maren.donig@gov.ab.ca Thanks.
kris erickson
07-22-2001 21:30:11
 Re: Re: onan engine in reply to Maren Donig, 02-02-2001 13:43:40
i just got a parts and service manual for my onan ccka from precise engine repair in oregon. the web address is-www.perr.com they were very helpful . be warned that parts are very expensive, i paid 319.00 for a crankshaft and the gasket set is 60.00 also this motor is way different inside than a briggs or kohler for example the main bearings (also 60.00) are a slip in fit you need to put them in the freezer and slide them in making sure they are lined up with the oil holes
mark
03-10-2001 18:54:11
See www.cummins.com
Afshin Khodabandeh
12-03-2000 04:52:09
I have an Onan engine Model CCK - MS /1281G
serial nr. 115c853235 This is on a snowmobile
Artic cat. I need to overhaul the engine and needs
som spareparts ( cam aksel, Overhaul sett )
Can somebody help me with manuals or som adresses.
<<<<Afshin
Comp:IOSA LTD.ŞTI.,,Exp.Mng. Mr.Fethi ÇİÇEK
03-26-2002 04:21:31
 Re: Re: onan engine in reply to Afshin Khodabandeh, 12-03-2000 04:52:09
Dear Sirs,
Our Company IOSA is one of the leading manufacturer of fuel lift pumps and their
related parts for cars,trucks,buses and tractors.
If you have interest please contact with us and we can send to you our catalogue
The fuel pumps with the brand names IOSA and DUSAN have been exported more than 15 Countries for year.Our pumps are in big demand in the markets in theese Countries.
Please do not hasitate to ask any further information.
We look forward to hearing from you in the near future.
Best Regards
F.Çiçek
Jerry
10-17-2000 07:17:20
Did you ever complete the re-build? I have the same welder and have purchased parts from Keen welding supplies. Phone number is 302-594-4545.
andy lambert
09-29-2000 18:09:54
The parts are still available for tat engine have have 2 of the same welders you are talking about and i just did a check on certain parts and they are outrageously priced compared to a simular Brigg or tecumseh engine. Unfortunately the parts have to come from an onan dealer of some sort. Hope this helped
weldon stockton
06-04-2000 15:38:18
I have a 1966 mail buggy with a Onan 2cyl. engine#cck-ms/1400g.I need a manual of some kind to help me with this project.Service ,parts,some kind of manual.It has fiberglass body,it is 3 wheeled,with 3 speed column shift.It has a steering wheel,not handlebars.I do not know what the proper name is for my mail buggy.Please help if possible.
rebatestore
06-09-2005 15:25:01
 Re: Re: onan engine in reply to weldon stockton, 06-04-2000 15:38:18
I found a rand three wheel mail carriar engine cck-ms 1244G my engine was built in march of 86
I can"t figure out the horse power?
medfarm
01-13-2000 18:10:45
Tom
I believe parts are still available.
Look in the yellow pages under small
engines. I just ordered parts for
a rare 4-cylinder onan generator.
I have a CCKB 2 cyl engine on a wood splitter.
These engines were made in the 70's.
Good luck.
Medfarm
Chris Turner
08-25-2001 10:05:16
 Re: Re: onan engine in reply to medfarm, 01-13-2000 18:10:45
I just picked up a 12.5kW genset with a 4cyl inline air cooled Onan. Is that similar to the one you have? If so, do you have any good sources for technical and owners manuals for such a machine or is my only source a Onan dealership?
Thanks,
Chris
