Help! Big Buckeye Diesel Engine
Eric Bloom
12-30-1998 15:04:28
Iam looking for any information on a huge stationary engine. It is a 5 cylinder 10" bore 12" stroke Buckeye Diesel made by the Buckeye Machine Co. Lima, Ohio. I would guess it was made in the 1920-1930 era. I believe I can make it run if I had more information. Thanks in advance
Donald Boyd
11-13-2002 10:06:02
 Re: Help! Big Buckeye Diesel Engine in reply to Eric Bloom, 12-30-1998 15:04:28
I've been interested in the big engines since I was a small boy and accompanied my father to the Buckeye Machine Company where he worked. The horizontal engines common to this area were one or two cylinders and rated at 90 or 180 HP. They had hot bowl ignition and were started by injecting compressed air into the cylinder. Many of them were run on automotive oil drainings and required the pump and injector to be rebuilt every year due to the sulfuric acid in the oil. They were rugged engines and could stand a lot of abuse. If they were running under heavy load and started to ping, water could be applied through a nozzle in the intake manifold to control that condition. The vertical diesel engines were of a newer design and were built in 2,3,4,5,6,7,8,& 9 cylinder configurations, which required a specific camshaft,crankshaft & base for each engine. Each cylinder had a separate cylinder head. The engines, I believe, were built in Model #70,80 & 90. The Marine model was equipped with a reversing transmission on the camshaft, injection pump and auxiliary equipment so that the engine could be stopped and then reversed so that the propeller on the craft could be reversed. The starting operation was done by compressed air, and a controller, called the Silent Watchman, was used to put the air into the cylinders. The engines were sold to customers all over the world, and there are many probably being used today.
JOE GOODMAN
01-27-2005 18:22:50
 Re: Re: Help! Big Buckeye Diesel Engine in reply to Donald Boyd, 11-13-2002 10:06:02
MR. BOYD,I HAVE HAPPENED UPON A 8 CYLINDER BUCKEYE ,AND AM CONSIDERING BUYING IT TO TINKER WITH, WHERE CAN I GET INFO ON THESE MOTORS
Jim smith Ft wayne
01-01-1999 20:36:42
I attend a antique engine and tractor show every
year, east of FT Wayne, in New Haven In. They have
a huge buckeye and run it every year. It's a hot
tube ignition, They turn it over with a big belt
to another tractor or engine. Email me and I will
get you a couple phone #'s you can call for the guys who own it.
Jim
The show is call Maumee valley gas engine and tractor show 3rd week in august.
Paul D CLUM
01-13-1999 12:50:39
 Re: Re: Help! Big Buckeye Diesel Engine in reply to Jim smith Ft wayne, 01-01-1999 20:36:42
What kind of help??? my dad useto run a big buck, and i live just a few miles from where they were built,, i have a small 1 to 2 hp buckeye.
twisted smith
01-22-2000 15:42:14
 Re: Re: Re: Help! Big Buckeye Diesel Engine in reply to Paul D CLUM, 01-13-1999 12:50:39
i to have a big buckeye
dont know much about it
est. weight 28000 lbs
est hp 80
Dan Hart
07-21-2000 17:55:55
 Re: Re: Re: Re: Help! Big Buckeye Diesel Engine in reply to twisted smith, 01-22-2000 15:42:14
I have one that is a 50 hp and I know quite a bit about them. I've been running mine for about ten years. If you have any questions or comments please e-mail me.
