Grinding Large Valve Seats; How?
TMAC
03-01-2000 19:14:16
The local auto shop can't grind the seat of my hit&miss engine because it is too big. How do you get around this problem?
Merlin
03-08-2000 20:54:40
 Re: Grinding Large Valve Seats; How? in reply to TMAC, 03-01-2000 19:14:16
Call around, there must be someone who can grind them. All it takes is the right stone. Try places that work on big stuff. May be a heavy duty deisel or farm equipment dealer. Also, sometimes thoses "little old shops that have been around for a 100 years" still have the right stones around.
John
03-01-2003 04:31:04
 Re: Re: Grinding Large Valve Seats; How? in reply to Merlin, 03-08-2000 20:54:40
if you haven't found a solution write me i can help
Ernie
03-03-2000 17:07:07
I was at a shop the other day that had the equipment to grind large valve seats. It is a ecentric type grinder that uses rather small stones to do a big job so to speak. Perhaps if you look for and old implement dealer they would still have that type of equipment .
ronm
03-02-2000 06:36:46
Where are you located? You need to find an older shop-they are more likely to have stones or cutters for bigger valves. How big are your valves? HTH, Ron.
