Briggs Stratton
Mr B.Hodgson
03-14-2000 12:13:52
I have a 3.5hp Briggs & Stratton horizontal lawnmower engine.
It runs for about 5 mins then smokes and back fires then cuts out, and is difficult to re-start.
Ive just had it serviced, but I doubt the servicer run it long enough. Any ideas
dallas smith
12-10-2000 20:37:24
 Re: Briggs Stratton in reply to Mr B.Hodgson, 03-14-2000 12:13:52
we are looking for a briggs@stratton 5 hp motor model 135282
type-0071-01
body ardisan
box 666
cumberlin wisconsin where it was made zip code 45820 need a motor bad'please give me a call at 614 759 8504 it is for a roto tiller.
mberlin wisconsin 45820
Bill De Loatch
06-11-2000 06:06:48
I have a 6HP 21-inch MTD mulching push mower from B&S with very simular problems. In fact, the mower would backfire like crazy whenever I would release the safety brake control handle. I would have to keep grabbing the safety handle and release it a few times before it would cut off. Then it would be difficult to restart. It finally got to a point where it would not start. I was told that I never put oil in it... I KNOW BETTER. I used it all last year. Did you uncover anything about the cause of your problems. I haven't had my mower a year yet. Thanks for any info you might share.
daniel
04-26-2004 18:05:01
 Re: Re: Briggs Stratton in reply to Bill De Loatch, 06-11-2000 06:06:48
check choke, and the wire to kill switch to the coil
Keidrick
09-25-2000 07:05:05
I have a brand new B&S 3.5hp on my go kart. model#91212 type 1060 e1 code#981007ya... I'm trying to get this machine to run a little faster.
I would like to know how do I take the governor off of this engine.
B. GREEN
06-02-2000 08:56:13
HAVE YOU CHANGED YOUR PLUG?
Josh
03-27-2000 16:49:17
It may have a falty gas cap vent. I don't know it you have tried this or not but loosen the cap some and then start it if it stays running well just get a new cap, if it doen't, well you know its not the cap.
