BriggsStratton 18 hp ic motor
Don G.
03-19-2000 11:33:43
engine will only run with full choke on. I believe it's probably time to rebuild carb if someone knows a different cure would like to here from you. thank you
david bowers
12-31-2000 12:53:46
 Re: BriggsStratton 18 hp ic motor in reply to Don G., 03-19-2000 11:33:43
dose any one know how to rebuild a go-cart motor
if you have plans e-mail them to me im so fed up
B GREEN
06-02-2000 08:53:43
CHECK AIR VENT IN GAS CAP
test
02-06-2001 16:08:21
 Re: Re: BriggsStratton 18 hp ic motor in reply to B GREEN, 06-02-2000 08:53:43
a
Greg Anselment
06-20-2000 19:55:20
Your main jet is plugged and carb needs to be cleaned go to dealer and get kit for it. This is a very simple job on this engine.
