Hercules motor parts
todd zier
06-01-2000 14:26:53
I HAVE A 1956 MILITARY 4X4 TRUCK (DAF) THAT HAS A HERCULES (YA126 ?) FLAT TOP SIX CLY.
I WOULD LIKE TO REBUILD IT, I"AM LOOKING FOR ANY AND ALL PARTS.
WATER PUMP (HELP)
IT RUNS OK.
THE FIRST CLY BURNS UP THE SPARK PLUG.
NOW IT IS RUNNING REALY HOT.
Dafmaf
11-27-2000 12:04:10
 Re: hercules motor parts in reply to todd zier, 06-01-2000 14:26:53
In holland where i live there are parts available for the dutch Daf YA 126.
This is because it was produced here in the netherlands.
The YA126 has a 88HP hercules gasoline engine with sidevalves. If good maintained it produces enough power to get the car trough the mud.
Try the adres:
Link
This is a dutch daf YA126 dealer and has most of the parts.
Bill in Mich
06-08-2000 21:02:24
Are you sure that the engine is not a JXLD? I know that they used them in many military applications. If so I may know of a couple of places that can help you , Bill
Barry
06-17-2000 11:59:30
 Re: Re: hercules motor parts in reply to Bill in Mich, 06-08-2000 21:02:24
In my particular case I have a similar engine and I believe you are correct bill. Although my model is actually QXLD5 I am curious if might be able to provide a parts source. My application is a former military spec welding trailer. Engine will not start due to low compression pressures. An accurate valve set in this case may improve results enough to restore startability but I have no valve set specs either.
all
03-24-2001 14:37:31
 Re: Re: Re: hercules motor parts in reply to Barry, 06-17-2000 11:59:30
sam winer 330-628-4881 parts
