Conneting road -perkins engine
Lefty
06-02-2000 06:42:30
What effect would a slightly bend connecting rod
to a runing engine.
hammerhead
06-03-2000 17:40:42
 Re: conneting road -perkins engine in reply to Lefty, 06-02-2000 06:42:30
It wouldn't be good especially if it's a diesel engine. First the bearing would wear out faster due to the misalignment of the rod and piston assy with the crank. Second if it is a diesel it would change the compression on that cylinder and since that's how a diesel ignites the fuel charge in the cylinder it could very easily cause a miss in the engine. Finally if you somehow avoided the above problems you would probably still have a nasty vibration.
Derek MacFarlane
04-19-2001 06:11:01
 Re: Re: conneting road -perkins engine in reply to hammerhead, 06-03-2000 17:40:42
I have an AC 840 Loader with a 4 Cyl. Perkins diesal in it. I'm having trouble locating a manifold extension for it it...anyone who might be able to cross over some old numbers would be very helpful tks..
Kurt Ray
12-07-2002 06:34:14
 Re: Re: Re: conneting road -perkins engine in reply to Derek MacFarlane, 04-19-2001 06:11:01
Try www.jamestroop.co.uk/perkins website
