Villiers 2 stroke info parts needed
Bill Klein
06-05-2000 20:33:40
I recently purchased a Villiers Mar Vel engine.
It needs the starting mechanism- the data
plate reads like it had a handle with rewinding
strap. Any parts leads or general info on this
UK made engine will be gratefully received. Bill
Yves Nadeau
03-03-2005 20:59:59
 Re: Villiers 2 stroke info parts needed in reply to Bill Klein, 06-05-2000 20:33:40
Now have a Warsop (made in England ± 1950-1960 year fabrication) internal combustible rock drill the engine is a Villiers 2 strokes motor (bore 2.5 inch stroke 3 inch) have a trouble with my diaphragm cabutetor Make AMAL if you have a parts or documents please send me a Email.
Thank you.
MEETENS INDUSTRIAL ENGINE
02-22-2005 06:55:57
MEETENS HAVE BEEN DISTRIBUTING VILLIERS PRODUCT SINCE 1908 AND POSSIBLY HOLD THE LARGEST STOCK OF SPARE PARTS IN THE WORLD
HAVE A LOOK FOR ANY ENGINE DETAILS AND EMAIL A PICTURE IT ALL HELPS.
andrew
10-20-2003 20:25:19
I am making one out of two that I have just got and unfortanitly I only have one of the parts you need between the two but Out of the remands of the pulling strap that was in it is exactly the same as shipping strap. If any one has any info on tis motor and what parts of it are soposed to be panted or even some pictures of any restored or unrestored please let me know and if you know of any sites that would help alot
Miles Hollins
06-06-2001 11:17:07
Sorry, but I don't have any parts available. But I was wondering if you could help me? I have a 2.5 horse Villiers that needs a lot of attention. Fortunately all the parts are there. However, the logos are all missing. I was wondering if wou had a decent copy of a logo that you could scan in and e-mail to me so that I can have it vinyl cut
Regards
Miles Hollins
P.S. I hope you eventually find the parts you are looking for.
chris
04-28-2002 02:28:27
 Re: Re: Villiers 2 stroke info parts needed in reply to Miles Hollins, 06-06-2001 11:17:07
Well i don't know a lot about engines i found you from ask.com.
Can you help me! I'm looking for info on villiers stationary engines, a friend has 1, with a water pump attatched ( to pump ouyt his boat) he's now trying to get it running .
it need a good clean as it's beeen at the bottom of the river. he's trying to get the fly wheel off, and dosn't know which way to turn the screw. Q. is it a left or right hand thread, and is the Main bolt the only thing that holds it together??
Adam Abbott
10-10-2002 12:03:45
 Re: Re: Re: Villiers 2 stroke info parts needed in reply to chris, 04-28-2002 02:28:27
this is exactly the same question i wanted toi ask! its just the thing!
ive got three and cant work out how to get the flywheel off!!
Todd Steiger
10-19-2003 21:28:28
 Re: Re: Re: Re: Villiers 2 stroke info parts need in reply to Adam Abbott, 10-10-2002 12:03:45
I just got a gas powered jackhammer that has a Villiers engine, I dont know much about it but, on mine the flywheel nut turns clockwise to remove the flywheel. I had to use an impact air wrench to get it off. The nut acts like a flywheel puller and is part of the flywheel, it is a very good design as it presses the flywheel on as well as pulls it off.
