What engine is it? Parts?
Ernie
06-20-2000 04:15:02
I bought an old engine and water pump a few years back. It wouldn't fire and after taking the flywheel off I found the coil was cracked open. I don't have much experience with old engines except tractors, and am lost as to what it is and if I can get parts. It appears to be 1-3hp, horizontal shaft w/gearbox, and I can barely make out a triangle logo with an oval over that with a name U_____ TOR on the gas tank. I can't make out the other letters but it had NY at the bottom of the logo. I think the engine was originally silver. The plate in the coil area says Bendix Scintilla, Model K1-9, S/N 070123. The coil has 2 clips that snap on to keep it in place. Is there a chance I can get the coil for this? Thanks.
Steve T
06-22-2000 20:32:27
 Re: What engine is it? Parts? in reply to Ernie, 06-20-2000 04:15:02
The name "Utilitor" comes to mind, other then that, we need some pix to look at to help you any more. Steve T
