Old vertical IHC Famous
Adrie and Jeann
07-02-2000 14:37:05
We have this old vertical IHC Famous engine for quite some time now, and the isolator in the ignitor goes every time it's running.
Adrie did all sorts of things, but now someone says that he probably uses a batterey with to much amperage or with other words, one that's realy to strong and that he'd better use an old one.
Does annyone recognise this problem?
We do have a friend with a simular engine and he has got the same problem.
By now Adrie has used all sorts of materials to solve the problem but nothing realy seems to last for more then a few hours.
Adrie and Jeanne oostvogels
05-27-2001 08:41:48
 Re: old vertical IHC Famous in reply to Adrie and Jeanne Oostvogels, 07-02-2000 14:37:05
third party image
As a matter of fact, Adrie has solved the problem and he did it (By accident?) unexpectedly.
A friend had the same sort of problem with the same kind of engine.
In the end it turned out that operating on an old bad battery it worked for hours on end without a flaw.
So what Adrie figured out is that the currency must have been much to high using a good battery.
Sorry but this was all there was to it.
Best regards of Adrie and Jeanne.
