How to time a wisconsin tjd model?
Serge Binette
09-04-2000 15:07:52
I just rebuilt the magneto for my wisconsin tjd model which is a 2 cyl.engine.
The problem is that there is no mark on the flywheel but there is one on the magneto gear.
soes someone can give me a tip to time this old engine?
Thank you very much
Serge Binette
Jon Hagen
09-12-2000 19:42:07
 Re: how to time a wisconsin tjd model? in reply to Serge Binette, 09-04-2000 15:07:52
I didn't reply to your post last week because My wisconsin manuals are for 1 and 4 cyl engines, The mag timing instructions are the same for 1 and 4 cyl so with luck it may work on your 2 cyl.
The flywheel should have an X cast into the end of one of the fan vanes which you line up with a mark on the top center of the flywheel air shroud.
You must remove the flywheel air screen to see these marks.
The X mark on the mag gear should be in the center of the inspection hole in the crankcase.
Hope this works, good luck.
Roger DiRuscio
09-15-2000 15:06:08
 Re: Re: how to time a wisconsin tjd model? in reply to Jon Hagen, 09-12-2000 19:42:07
You will need to snap the impulse on the mag or the spring will keep moving the gear when you try to install it
