40 horse Bovaird and Seyfang
Mark Congden
09-21-2000 17:09:10
I just aquired a 40 horse bovaird and seyfang two cycle cross head engine. It is fired by a WICO OC magneto and has a stitt long shank spark plug. This is my first experience with a natural gas engine and i cant get it to fire on propane. It will fire on gasoline when i prime it. My question is,how much spark is needed to ignite propane? The spark is the same as a WICO EK, should the big WICO OC put out more voltage,more spark?
Steve Cox
09-25-2000 01:45:55
 Re: 40 horse Bovaird and Seyfang in reply to Mark Congden, 09-21-2000 17:09:10
Mark,
The same spark will work on propane. The ratio of air to gas is hard to determine the first time starting these big engines. I have found that it is very easy to flood an engine with propane. Try reducing the amount of propane or increase air ratio to cylinder.
