Fairmont gas engine
Petcock
01-24-1999 19:42:37
Just got a Fairmont 2 flywheel 2cycle engine. It has a cooling tank;not a radiator, and has a buzz coil for ignition. It's complete and looks like it should run. What can anyone with experiance with these railroad car engines tell me about starting and operating this thing?
How does the engine operate in either direction?
Dick Lotspeich
10-31-2000 10:23:56
 Re: Fairmont gas engine in reply to Petcock, 01-24-1999 19:42:37
I have an early fairmont 6HP,slyle QH.It has a solid bronze carb,and cast steamer tank.Ive gone through it and looks really nice,but as you all know ,it does run a little wild.I'm looking for a good pic of the cart for it,so I can try and find/build one,and would appreciate any help.
Joel Varner
06-24-2000 18:58:10
Hooray for the 2 flywheel 2 cycle Fairmont. I have a 6 hp.! It does run in either direction, but you have to move the timing lever to acommodate the direction in which you start it. These engines are fun to work with,but they can be trying at times. I had to make a few parts for mine. To petcock, I say if you do junk yours, please give me the chance to buy it.
Richard Elm
09-03-2000 11:46:00
 Re: Re: Fairmont gas engine in reply to Joel Varner, 06-24-2000 18:58:10
Just picked up a fairmont engine the other day and have figured that I will never get around to restoring it. If you are interested let me know. It is missing carburator and ignition. The piston is stuck but I think that the right person could make it go again or use it for parts.
Donnie Irvin
01-05-2000 17:50:41
Looking for information on engine with serial #38699. Type QB. Looking for engine manual and a buzz coil or magneto. Would like to know which
this engine uses?
Thank you
jack wynings
09-13-2001 05:20:57
 Re: Re: Fairmont gas engine in reply to Donnie Irvin, 01-05-2000 17:50:41
i just purchased a 4hp fairmont with a wico mag,
model phma, is there a operators manual available on this engine. any info. will be appreciated. thanks jack
jack wynings
09-19-2001 05:16:09
 Re: Re: Re: Fairmont gas engine in reply to jack wynings, 09-13-2001 05:20:57
i still need some help with this engine, can some one be of any help? thanks jack
TMAC
02-09-1999 16:28:11
I have seen a few Fairmonts running at some shows. They run fine and with a dual stack, one sounded like a Harley-Davidson. I have a copy of the manual for these engines so if you need one I can send a copy to you.
Larry Dyck
02-08-2005 19:21:27
 Re: Re: Fairmont gas engine in reply to TMAC, 02-09-1999 16:28:11
My father has an 8 hp fairmont engine and it needs
a little work, if you still have a copy of a manual for this engine I would greatly appreciate a copy. Thanks
jack watkins
10-15-2002 06:57:49
i have a rq model fairmont engine i am in the process of restoring. if you still have the manual you spoke of i would be glad to buy it or a copy.
Ryan De Paoli
07-23-2002 06:21:37
hi i have a fairmont engine and was chasing a manual for it. It would be greatly appreciated if u could foward that to me as i have had no luck in finding one. Hope to hear from u soon.
Ryan
Ray Harry
01-12-2001 19:33:51
I have one of these engines #91459 and need any information that I can get. I would like to pay you copy and mailing costs for a copy of your manual or if they are available somewhere where could I get a hold of one?
Please E-Mail me. Thanks Ray Harry
Joe LeBlanc
09-22-2000 16:45:37
I have an 8HP Fairmont which runs fine in either direction. I have not been able to change from one direction to the other while the engine is running. I have also not been able to find a manual on these engines which may shed light on how to do this. If are still able to send a manual copy please let me know via e-mail, and I will be glad to reimburse you for your troubles. Thanks, Joe
jim king
03-04-2000 19:27:20
can i get a copy of the copy of the fairmont engine manual?? i have an engine that runs pretty good in either direction.. would like a little more info on it .. thanks jim king
Doug T
01-28-1999 18:24:05
I had a Fairmont eng blow up while attempting to start a fresh restoration w/tractor. 20+ yrs. ago and still shudder every time I see one at shows. They run fast and erratic w/o load. Don't think I've seen one run slow and don't have the guts to try. Have good tension on timing lever as it can change in the blink of an eye. Air leaks into the crankcase are a prob.-especially main brgs.
petcock
01-29-1999 11:34:54
 Re: Re: Fairmont gas engine in reply to Doug T, 01-28-1999 18:24:05
It sounds like I'd better junk it and get a Maytag instead!
Wayne Otteson
01-28-1999 00:00:36
I don't have alot of experience with the Fairmont engine but because it is a 2 cycle engine it will run in either direction, the direction you want it to run is determined on which way, either clockwise or counter clockwise, you turn the flywheel to start it.
Joel Varner
06-24-2000 18:52:34
 Re: Re: Fairmont gas engine in reply to Wayne Otteson, 01-28-1999 00:00:36
Whooray for the 2 flywheel 2 cycle Fairmont! I have a 6 hp . It does run in either direction, but you also need to move your timing lever to accomodate the direction you are starting it. They are fun to work with, but can be trying at times. I had to make a few parts for mine. To the person who was debating on scraping it and getting a Maytag, I say please do and please give me the chance to buy it.
