FORD Industrial Engines
S.AMMER
12-10-2000 15:19:44
Did Ford Motor Company ever make an industrial or stationary engine using an 8BA or similar flathead V-8?
Mike Thoomson
05-17-2002 16:01:08
 Re: FORD Industrial Engines in reply to S.AMMER, 12-10-2000 15:19:44
need a ford 192 cu in 4 cyl gas long block or ocerhaul kit
MIKE THOMSON
05-15-2002 14:26:51
need 4 cyl ford gas engine "d3jl 6059-c" goes in a fork lift, located in Houston Tx
Mark's Service
03-02-2002 13:51:19
I need to know the model number and valve clearence for a 102 cubic unch V4 ford industrial engine.Also do you know where I can get parts?
manuel
01-12-2001 13:00:28
i think they used them for search lights, welders & lighting plants during the war.
Björn
10-08-2001 04:45:15
 Re: Re: FORD Industrial Engines in reply to manuel, 01-12-2001 13:00:28
Hi Folks,
Does anybody know in what car they used the ford 170GF engine?
I have a Hobart welder with such an engine but somebody swiped the distributor and now I can't find any spares.
Here in Namibia they look at you with big eyes if you ask them for spares of that engine.
Any clue what other engine's distributor might fit??
Any help would be greatly appreciated
IaGuy
12-20-2000 19:15:16
In 1950, a travelling hammermill on a truck chassis came to our farm to grind feed. It had a Forn V-8 flathead driving the hammermill. A control panel with choke, key starter, fixed position throttle and big tachometer. As I remember the rear bell housing had a clutch lever out the side.
Ollie
12-15-2000 04:47:44
Sure did, its been awhile since I've seen one but remember one in the late 50's, early 60's, running an ice chipper/blower that would take 100# blocks of ice and chop them up and blow the "snow" atop loads of produce to keep them cold on the way to market. This was BTK (before Thermo Kings)
S.AMMER
12-16-2000 06:47:36
 Re: Re: FORD Industrial Engines in reply to Ollie, 12-15-2000 04:47:44
Thanks for the information Ollie, maybe some one else can come up with more info. There is a man about 30 miles from here that has a portable power unit built by his ganndfather in the 40's. They used two 85 hp v-8 engines,transmissions and truck rear ends to drive a flat belt pulley.The unit is mounted on a 34 ford truck for mobility, a real nice running unit.They take it to the shows around here.Thanks again.
