IHC LA
Red Raider
01-13-2001 17:20:18
I've taken on a small engine project from my usual tractor restorations. Today I pulled the cylinder head, carb, gas tank, inspection cover, and the cover opposite from the pulley. The oil had seemed to have crystalized and turned to wax/carmel substance. Most if it came out with a screwdriver after heating the casting with a small portable heater. I was amazed there was so little wear on the cylinder walls, bearings, and gears, although the 45 or so idle years had allowed the governor gear to be partially eaten away by the old oil that had become corrosive. Apparently, aluminum gears corrode faster that cast iron. Anyway, I need a cylinder head gasket, several gaskets, IHC gray (before '36), and decals.
hammerhead
01-14-2001 10:59:20
 Re: IHC LA in reply to Red Raider, 01-13-2001 17:20:18
Try www.gasengine.com this is a list of suppliers and clubs that I found awhile back.
DONNIE REDDING
01-28-2001 05:49:20
 Re: Re: IHC LA in reply to hammerhead, 01-14-2001 10:59:20
YOU CAN PURCHASE PARTS FROM SEVERAL SUPPLIERS.ONE OF THE TO CALL IS OTTO GAS ENGINE WORKS (410)398-7340. ALSO HIT AND MISS ENTERPRIZES (440)272-5335 AS K THEM TO SENT YOU A PARTS BOOK ALSO YOU CAN PURCHASE A OWNER MANUAL. GOOD LUCK
Roger
02-02-2001 03:09:33
 Re: Re: Re: IHC LA in reply to DONNIE REDDING, 01-28-2001 05:49:20
you can download a manual from this site
http://www.oldengine.org/docs/
