Craftsman 2100 generator
Joe Reilly
02-10-2001 10:33:34
I inherited a Sears generator from a friend without instructions. The unit is from the early 80's. This model has a lever over the gas tank that may be the fuel flow control. It also has a vertical rod that appears to connect to the carb that has a up position (held up by a small spring)and a lock down position. It also has an Off/On switch. I do not know how to set these controls and I am unable to start the unit. Could anyone help with some onfo on starting. I think the vertical rod may be a choke(just a guess). Thanks in advance
Jorge Ochoa
10-21-2005 18:07:21
 Re: Craftsman 2100 generator in reply to Joe Reilly, 02-10-2001 10:33:34
my generator just had a carb. installed and gas tank. there is no electricity coming out.all wiring they said was ok. someone mentioned it need to be shocked. i dont know please respond thanks
