INTERNATIONAL 1 1/2
DONNIE REDDING
03-17-2001 03:34:09
I AM HAVING TROUBLE WITH THE FUEL PUMP. THE FUEL PUMP SEEMS TO BE LEAKING GAS AROUND THE PLUNGER WHEN THE ENGINE IS RUNNING. ANY IDEAS. MANY THANKS
steve
03-18-2001 04:57:40
 Re: INTERNATIONAL 1 1/2 in reply to DONNIE REDDING, 03-17-2001 03:34:09
The plunger is lapped-in to fit the housing on these pumps. After years of use they are known to leak. Options 1 - have a heavy coat of plating applied to the plunger and then re-lap it to fit.
2 - Have a new plunger made oversize. 3 - Try to machine a groove at the bottom of plunger and add an "O" ring to seal. 4 - Buy a new a pump, a number of dealers have replacement pumps. I did the "O" ring trick on my 1 1/2 which powers a can crusher a number of years ago. It works to some extent, I find that I have to replace it every season.
DONNIE REDDING
03-18-2001 06:21:55
 Re: Re: INTERNATIONAL 1 1/2 in reply to steve, 03-18-2001 04:57:40
DEAR STEVE;
I APPRECIATE YOUR HELP ON THIS DONNIE
BOBRR
04-01-2001 10:16:44
 Re: Re: Re: INTERNATIONAL 1 1/2 in reply to DONNIE REDDING, 03-18-2001 06:21:55
theres supposed to be valve packing around the plunger! you can get some from plumbing store. you want the good stuff with graphite. wrap a couple turns around plunger and lightly pack in.then oil you may have to pack and oil acouple of times till makes good seal then oil asneeded.
