BS ENGINE------1929 MODEL-FH
BIG JOHN
04-05-2001 23:17:43
I JUST FOUND A FH MODEL ENGINE. MY QUESTION IS DOES THIS MOTOR REQUIRE TWO FLYWHEELS TO RUN? I FOUND A PICTURE OF IT ON THE "OLD IRON" SITE UNDER B&S ENGINES AND IT SPECIFIES THE TWO FLYWHEELS. THE ONLY PIECES THAT I DO NOT HAVE ACCORDING TO THAT PICTURE IS THE FLYWHEEL AND THE FUEL TANK.ALSO DOES THE CARB. REGUIRE A SUCTION TUBE INTO THE TANK FOR I HAVE THE CARB AND THERE IS A HOLE ,SO I FIGURE IT GOT TO HAVE A TUBE THE DEPTH OF THE TANK TO SIPHON. THE SHROUDED FLYWHEEL IS THERE,BUT THE DRIVE SIDE OF SHAFT DOES NOT HAVE ONE, AS THE PICTURE SHOWS! THE SHROUD SIDE HAS ONLY A HEX ON THE END OF THE CRANK SHAFT, IS THIS WHERE A ROPE TYPE PULL STATER SHOULD GO, IF SO I`M MISSING THAT TOO. HOW HARD ARE THESE PARTS TO FIND, THANK YOU FOR YOUR HELP ! BIG JOHN IN PENNA.
