International LB
scott
05-05-2001 19:17:52
OK, now I have a new fuel tank, a new fuel line with check valve. The carb has been cleaned and has new gaskets. I have a new needle valve. And I still can't get it started. Not even a back fire and when I pull the spark plug it is always dry. I don't think it's pumping fuel. Any ideas?
Wayne
12-27-2003 18:00:08
 Re: International LB in reply to scott, 05-05-2001 19:17:52
I have a Model LB SN 44165. Anybody know where should the DC mark be on the fly wheel should be when you try to start the engine?
Thanks.
Red Raider
05-06-2001 16:38:54
Check the cylinder for gas with a flash light, it could be flooded as mine did at 1 turn. A quarter turn did the trick. Also, try spinning the crank, thumb over, not under. This method worked for my '36 LA. The plug will not be wet with gas even if the engine is flooded.
Tom
05-05-2001 19:43:14
How many turns out is the mixture screw? Turn it in all the way by hand. DON'T FORCE it with a screwdriver. Then turn it out 1 & 1/2 turns. The engine should start at this setting. If this doesn't work, then take a screw off cap from a soft drink bottle, pour in a little gasoline, and then remove the spark plug. Pour the gas through the spark plug hole, replace the plug, and try to start the engine. It should at least hit a couple of licks.
scott
05-05-2001 22:29:39
 Re: Re: International LB in reply to Tom, 05-05-2001 19:43:14
Ok I'll let you know.
Tom
05-07-2001 19:11:49
 Re: Re: Re: International LB in reply to scott, 05-05-2001 22:29:39
My mistake on the number of turns. I was tired and thinking of a Briggs. Try just turning it out about a 1/4 turn. Sorry about that.
