Genset Info
Don Fielding
06-01-2001 18:44:10
I need to find a source for service manual and parts (especially rebuild gasket sets) for the following diesel genset. I would also like to obtain a copy of the generator control wiring including the value and ratings of the rheostat. Please advise if you can furnish these items?
Thank You
Don
REINER GENERATOR SET
MODEL DGH 25 AC
SERIAL # 16507 : ELECTRIC MACHINERY CO. SERIAL # (I K946672)
RATING 25 KW VOLTS 120 / 208
TYPE AC PHASE 3 CYCLES 60
ENGINE RPM 1800
CONTR E 26813
INSP G DATE 7-22-57
GENERATOR ARMATURE 0.0513 OHMS
GENERATOR FIELD 5.13 OHMS
EXITER ARMATURE 0.1950 OHMS
EXITER SHUNT FIELD 20.77 OHMS
NO LOAD CURRENT 4.0 AMPS
FULL LOAD CURRENT 9.5 AMPS
AIR GAP 0.084 INCH
ENGINE DATA PLATE
FIRING ORDER 1-2-4-3 TIMING ----- ----- --
SPEC D226X105 MODEL DD226H
SIZE 4 X 4-1/2 MAIN LUBE OIL PRESSURE 20 lb.
TAPPET CLERANCE EXH. 0.015 INT. 0.015 HERCULES ENGINES INC.
JOHN REINER & COMPANY
12-12 37th AVENUE
LONG ISLAND CITY 1 N.Y. 11101 HERCULES DIESEL
INJECTORS
AMERICAN BOSCH AKF 77 S
MADE IN SPRINGFIELD, MASS. U.S.A.
2-57 INJECTOR PUMP
ROOSA MASTER
MODEL # D1GV. CC. L. 429.13S
RPM 1800
SERIAL # 26443
MFG. # 260559. DS
HARTFORD MACHINE SCREW CO.
HARTFORD, CONN. U.S.A.
DIVISON OF STANDARD SCREW CO.
GENERATOR LEAD MARKINGS
T- 0
T- 1
T- 2
T- 3
A- 1
GF-1
A- 2
GF- 2
F- 1
F- 2
Zira
06-02-2001 04:59:48
 Re: Genset Info in reply to Don Fielding, 06-01-2001 18:44:10
Try posting your question at this site:
Link
