Sandow engines
SJ
02-15-1999 12:25:48
I'm looking for any kind of information on Sandow engines. The one in question has a brass tag saying it was manufactured by the Detroit Motor Car Supply Co. It has about a 12-14"double groove V-belt pulley,mated with about a 5" flat belt pulley on the same side. My guess is that it ran machine shop equipment. It is a 2 cycle,it has a moveable lever to adjust the ignition timing.It will run in both directions.It has an upright cylinder,water cooled,and I'm guessing somewhere around 3-5h.p. Any information on specifications or history would be appreciated. Thanks S.J.
Tom Rediske
12-23-2001 20:21:11
 Re: Sandow engines in reply to SJ, 02-15-1999 12:25:48
I have also have a Sandow upright Engine #3179, with a lever and oiler hour glasses. It not running I going to restore. It was on a ranch used to pump water. I have not found much info on it either I would appreciate it if you get any info please contact me & I'll do the same for you
Thanks Tom Rediske
Helena, MT
ed long
11-28-2003 13:49:13
 Re: Re: Sandow engines in reply to Tom Rediske, 12-23-2001 20:21:11
I also have the engine you are describing i need any info anyone can supply also thanks Ed
Bob Gillson
04-01-2005 22:16:35
 Re: Re: Re: Sandow engines in reply to ed long, 11-28-2003 13:49:13
I just located a Sandow engine, as described in the initial posting, in running order. It is available but I have no idea as to it's value. Can anyone give me a "ballpark: estimate as to value? Thanks. Bob
