LeRoi 4cyl stationary
Heather Kennedy
09-20-2001 17:53:07
We have a very old stationary motor,LeRoi serial # 87523 (no model#) with an Eismann magneto. It's a 4 cylinder gas motor approximate dimensions 2'w x 3'l x 3'h. It has a small brass dome-topped radiator & a barrell-shaped gas tank with a cast "gas" cap.The tag simply says Le Roi #87523 Milwaukee. Someone suggested that it was originally a kit made from early Ford Model A or T parts. Someone else wrote to us suggesting it might be a D176 or D201. Any words of wisdom for the undereducated? Thanking you in advance for your input. -HK
Ken Lively
07-09-2005 20:01:43
 Re: LeRoi 4cyl stationary in reply to Heather Kennedy, 09-20-2001 17:53:07
Leroi Milwaukee radiator for sale, NOS. NOS #71-440-111. Tag says Model 64?, EC+ Sheet Metal& New radiator. 19" Wide, 29" base to top of header tank, 6" O'all width. 17 5/8 Dia fan hole in rear shroud. Header tank is brass. Weight appx 50 lbs. Email me for pix. Palatine Illinois, 60067. $29.99 + S/H, or you PU, NC
Ken Lively
Polepenhollow [EBAY name] look up my feedback
Jim Couch
09-22-2002 21:18:21
I have a Le Roi 4 cyl. on a 2 drum hoist made by Clyde Iron Works. If you find any info please let me know and I'll send you any that I find. Mine's missing the magneto so you've already helped me some! Thanks!!!!
jud fisher
10-19-2003 04:56:53
 Re: Re: LeRoi 4cyl stationary in reply to Jim Couch, 09-22-2002 21:18:21
there is a guy who sells le roi 4 cylinder manuals on e-bay...even if maunal is not for this specific engine, there might be enough generic le roi info to give you some insight into how your engine runs, etc....check under "leroi" and "le roi" (space between the word "the" and "king")
TAK
09-20-2001 20:29:04
Heather~Waukesha Motor Company acquired the LeRoi line in the early 1950's. Most data at this point was destroyed. The four cylinder Model CR engine was a extremely popular...its 31/8 X 41/2 inch four cylinder engine powered a great many lightweight tractors of the 1920's and 1930's, including International Harvesters' motor culivator.
