Briggs model ZZ
Scott
09-26-2001 10:56:00
Does the model ZZ briggs and Stratton engine use the same points and condenser as later models? Does anyone know part number? It is a model ZZ with sheet metal shroud. Thanks in advance for all information.
another doug
10-15-2001 04:56:04
 Re: Briggs model ZZ in reply to Scott, 09-26-2001 10:56:00
Scott,Here are the part numbers for you Briggs and Stratton ZZ .The breaker points set is 291408, the condenser is 29861, flywheel key is 66403. We have had ours for over 35 years , it is on a wheat sowing tractor, needs a valve job as compression is not good, these engines are only rated at 6 or 7 hp! But it honest horsepower! Let me know how things are going with it, Good Luck!
Scott
10-15-2001 09:19:39
 Re: Re: Briggs model ZZ in reply to another doug, 10-15-2001 04:56:04
Thanks for the info Doug. I've got it up and running now, but I am going to get those points, condenser and key. I ran the numbers and mine was built in Feb. 1945. That tells me B&S was doing something right. Thanks again for the info.
