Briggs WMB Flywheel
JW(NC)
09-27-2001 18:13:59
New owner needs to know:
1) How do you hold the flywheel so you can loosen the left hand nut? Is there a tool?
2) I broke off two fins, is there a fix? Are they alumimun or pot metal? Can they be welded back? Or can I epoxy them on without them flying off?
Learning the hard way.....
Thanks for your help.
Andrew
10-12-2001 19:37:06
 Re: Briggs WMB Flywheel in reply to JW(NC), 09-27-2001 18:13:59
you can break two fins off from across the two you already broke off. There is a special tool made by briggs for holding the flywheel. You also can take out the spark plug and put some twine in the cylinder.
Andrew
another doug
09-27-2001 21:06:06
I got a flywheel at the Portland, Indiana engine show in August ,think it was for a model N ? has 32 teeth and two small sqaure magnets with dimples in them, also a tapered sfaft, I uh, broke the hub with an impact wrench , yeah reverse threads, whoopsie, I paid $8 for a nice used flywheel, saw others too, $10 for a new one! If they are interchangable , just get a replacement, I wouldn't fuss over glueing or welding , I worried for months before I found it, for nothing...parts are out there! Good Luck!
