Maytag Model 31 Flywheel
JW(NC)
09-28-2001 16:32:06
New owner with no experience.
How do I take the flywheel off?
The steel hub with the keyway in it is stuck.
Is there a trick to breaking this loose?
I don't want to break anything!!!!
Thanks for your help....
Frederick C. Douglas
12-20-2005 18:40:10
 Re: Maytag Model 31 Flywheel in reply to JW(NC), 09-28-2001 16:32:06
soak with PB BLASTER for a while then with a 3 jaw puller ,tighten the center bolt then tap with a hammer,turn a little more tap again ,repeat till she comes loose.
dont use your 1/2" air impact gun as you will not be able to feel the metal giving way.
my $.02 worth
