Maytag Model 31 Stuck Cylinder
JW(NC)
09-28-2001 16:39:19
Bought this engine with a stuck cylinder.
Replaced the sparkplug with a half inch reducer pipe bushing with a grease fitting.
Filled with grease and started pumping. Had to block off the exhaust and pumped so more. Now I am to the breather opening in the engine block. This goes all around the opening. How do I block this off so I can continue with the hydraulic action and pump the cylinder out?
Stumped, but no defeated!!!
Frederick C. Douglas
12-21-2005 17:28:13
 Re: Maytag Model 31 Stuck Cylinder in reply to JW(NC), 09-28-2001 16:39:19
use the eletritrolisis (sp) method.
drop that whole engine into a bath of washing soda or baking soda and water attach the positive lead from a battery charger to a steel plate lying on the bottom,attach the negitive lead to the engine>note use a bit of chain or a wire to keep the lead ends out of the solution,as it will corode the snot out of them.<
crank that battery charger up to the highest amp setting you have and watch the rust leave the engine.this will take a bit of time and you will have to stop and clean the steel plate from time to time as the part loses it's oxide coating.
lots of info on the web about it .
I have used this method and belive me it works better than ANY other way.
Baggsy
09-29-2001 20:52:07
Can't help with the problem but you might trundle over here...
Link
whole lotta people that really know their old engines on this forum. They'll know what you're up against...
