Engine timing
Raymond Bagwell
10-11-2001 22:21:33
I have an engine I believe to be an Economy. The serial number plate has been damaged. It does have 2 1/4 HP , 600 RPM and Sn. 48663. I need to know how the cam timing lines up with the crank I can see the timing mark which appears to be a large arrow on the cam gear but the only thing I see that could be anyting close on the crank gear is a tooth that appears to have been damaged slghtly with a coule of hash marks on it. Thanks for any help identifying this engine or getting the cam timed properly.
Baggsy
10-12-2001 18:56:02
 Re: Engine timing in reply to Raymond Bagwell, 10-11-2001 22:21:33
www.hitnmiss.com has manuals listed for the Economy's, and can probably help you with your problem. I think they were timed to spark at TDC, seen beveled teeth and dotted teeth, or flywheel marks that line up a certain way. Keep us informed and good luck!
