Maytag, help TAK
Mike S
10-20-2001 18:35:24
You have been a great resource and I appreciate it. It ran yesterday like a top. Now it will not fire at all. What should I look for? It has fresh fuel mix, 16 to 1. Brand new plug that shows spark when laying on the side of the engine. Compression is good, tho I have no idea what PSI it should be if I could hook up a gauge to it. Plug gets wet, so I'm thinking it is getting fuel. Any thoughts would be appreciated.
TAK
10-20-2001 20:37:15
 Re: maytag, help TAK in reply to Mike S, 10-20-2001 18:35:24
Mike ~ Glad to hear you got it running! The engine likely has a stuck check valve at the bottom of the fuel line. This can be accessed by removing the carb. It is attached to the crankcase by four brass screws. GOOD LUCK!
