Large Ring Compressor?
TMAC
02-26-1999 12:49:44
I'm trying to re-install the piston of a 6hp Root & VanDervoort engine. Its too difficult without a ring compressor. Does anybody make a compressor for pistons 7" in diameter or larger?
Gman
03-14-1999 01:50:21
 Re: Large Ring Compressor? in reply to TMAC, 02-26-1999 12:49:44
TMAC I use a stainless hose clamp to compress the rings on my "G" John Deere's I can't get them all at one shot,but the hose clamp isn't expensive either . later Gman
Chad Wink
03-10-1999 17:48:36
Put some effort into looking for the real thing, I have one that goes to about 8.5 inches. I don't remeber for sure where I got it, but I do remember it not being all that hard to find. MAybe O.T.C., or Snap-On?
After you brake a ring, you may wish you had boutht the right tool.
Doug T
02-26-1999 19:07:40
Check with a good auto parts store for very large hose clamps. An application would be air intake on semi. should be able to find right size. put 2 together if nec. Wrap thin sheet steel around rings and clamp down or use on 1 ring at a time.
TMAC
03-11-1999 16:19:40
 Re: Re: Large Ring Compressor? in reply to Doug T, 02-26-1999 19:07:40
Thanks for suggestions. I tried the larger hose clamp ring and a piece of metal roofing. It worked. I'm happy.
