Mccormick deering LA fuel problem
justin
08-08-1998 19:14:48
I just bought a mccormick deering LA, and the motor is having what appears to be a fuel pickup problem. The thing that I noticed, is that the fuel line fitting that enters the gas tank, is about a quarter inch larger than the fuel line.. So my question is: Will this gap keep the motor from drawing the fuel from the motor?? I would also liketo know where I can bu parts for this motor.. Thanks for all the help..
Kevin H.
08-09-1998 21:42:52
 Re: mccormick deering LA fuel problem in reply to justin, 08-08-1998 19:14:48
: I just bought a mccormick deering LA, and the motor is having what appears to be a fuel pickup problem. The thing that I noticed, is that the fuel line fitting that enters the gas tank, is about a quarter inch larger than the fuel line.. So my question is: Will this gap keep the motor from drawing the fuel from the motor?? I would also liketo know where I can bu parts for this motor.. Thanks for all the help.. To answer your question, no the gap will not affect the fuel pickup on an LA or LB.
I have ran one of mine off of a plastic Coke bottle cut in half.
Most likely, your problem is with the check-valve in the bottom of the fuel line.
I have been able to get some parts from Starbolt Engine Supplies.
You can call them for one of their catalogs. (301)874-2821
If I can be of any further help, email me and I'll be glad to help.
good luck,Kevin H. (harbin@innova.net)
justin
08-09-1998 21:57:03
 Re: Re: mccormick deering LA fuel problem in reply to Kevin H., 08-09-1998 21:42:52
: : I just bought a mccormick deering LA, and the motor is having what appears to be a fuel pickup problem. The thing that I noticed, is that the fuel line fitting that enters the gas tank, is about a quarter inch larger than the fuel line.. So my question is: Will this gap keep the motor from drawing the fuel from the motor?? I would also liketo know where I can bu parts for this motor.. Thanks for all the help..
: To answer your question, no the gap will not affect the fuel pickup on an LA or LB.
: I have ran one of mine off of a plastic Coke bottle cut in half.
: Most likely, your problem is with the check-valve in the bottom of the fuel line.
: I have been able to get some parts from Starbolt Engine Supplies.
: You can call them for one of their catalogs. (301)874-2821
: If I can be of any further help, email me and I'll be glad to help.
: good luck,Kevin H. (harbin@innova.net)
While making a new fitting today, I realized that the previous owner had reassembled the valve wrong, and the valve would hang up in its carrier tube.. thanks for the help..
